SGI-5B Signal Noise
Old Oct 7, 2005 | 08:49 AM
Bones232's Avatar
Car: 1991 Camaro RS
Engine: 355 Vortec TBI
SGI-5B Signal Noise
I'm using the Dakota Digital SGI-5B speedo signal converter to convert the vss signal from my T56 to my tbi ecm. Every so often my speedo jumps around. I figure i have a noisy ground or am picking up noise through my signal wires from the vss.
I have twisted the wires from the vss to the sgi box, as suggested in the directions, to help shield the signal with no luck.
Has anyone out there conquered this demon?
Old Oct 7, 2005 | 03:41 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Not yet (have the same problem), but working on it. Thinking the wire needs to be shielded ub the ECM area, still trying to figure this one out.....
Old Oct 7, 2005 | 04:06 PM
Bones232's Avatar
Car: 1991 Camaro RS
I was thinking about using some aluminum foil to wrap the signal wires to see if it would make a difference.
I also tried a 1 uf cap across the signal input and ground to see if i could isolate the noise. no dice.
Old Oct 11, 2005 | 10:35 AM
Bones232's Avatar
Car: 1991 Camaro RS
ttt
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
lewandom
Oct 1, 2015 08:15 AM
