Wierd noise from t-5 when in neutral
Old Oct 8, 2005 | 08:36 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
hey guys, say i put it inneutral and start the car, no noise but if i throw it in first then back into neutral and let the clutch out, i hear a spinning noise going along with the engine, ive heard this could be the input shaft bearing or something like that
btw this is a 87 formual 350- from a auto- manual trans swap
Old Oct 9, 2005 | 05:49 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Put it in neutral and push the clutch in, does it go away? If so I'd bet it's the throwout bearing.
Old Oct 9, 2005 | 07:37 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
yep quiets right down with the clutch in
now will this hurt the clutch or anything, jw because i probly wont have cash/resources to go hinkering around in there for a while
Old Oct 11, 2005 | 06:28 AM
crazycrocket's Avatar
Car: 1985 camaro
throwout bearings are very cheap. I think I got mine for like 8 bucks canadian when I did mine.
Its a quick job, just get it done before the thing seizes on you. Its a pretty simple swap, undo u joint, pull tranny and bell housing, pop old one out, slip new one in. re assemble, and gravity bleed your clutch, or don't and only bleed if you have to pump your clutch for it to work.
Old Oct 11, 2005 | 09:02 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
so say it seizes, what happens? lol
mud runner
Nov 2, 2015 07:30 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
lanceflame44
Sep 25, 2015 12:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
