TH350 full manual valve body reverse pattern problems
Old Oct 17, 2005 | 09:59 PM
EvilCartman's Avatar
Car: '82 Z28
Friend of mine is having problems with his Hughes full manual valve body. He's gotten 2 units now from the factory that have no reverse gear. You can rev the engine to the moon and the rear wheels hardly twitch. All the forward gears shift perfect and do not slip. The valve body has been installed both times by a trans shop that has a good rep but they also don't know what's up. Anyone here run into the same problem or might have some input on to what's going on?
Old Oct 17, 2005 | 10:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Does the valve body have a transbrake?
Old Oct 18, 2005 | 04:31 AM
Car: '82 Z28
No transbrake. While my friend was waiting for a second valve body the trans guy put in his old stocker unit which did have reverse working. Soon as the new valve body went in today (which he said was different from the first one) he once again had no reverse but other gears were fine.
Old Oct 20, 2005 | 01:38 AM
Car: '82 Z28
Well, as it turns out it was Hughes' bad documentation with the valve body. In the (partial) instructions they say to only use one thing from the stocker valve body. Turns out you also need the modulator valve too, there's a plug that fills the hole and holds this valve in place. My friend called Hughes up today and asked them about it, they didn't even know at first. So all in all, it was just one little thing keeping the car from going into reverse. Everything is working perfect now and he can go racing again hehe.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
lakeffect2
Aug 23, 2015 08:44 AM
hokis
Aug 9, 2015 03:57 PM
