4th gen diff swap
Old Oct 27, 2005 | 10:15 AM
1st3rdgen23's Avatar
Car: 1990 RS
Engine: 305 tbi (currently)
Transmission: B/W 5spd
4th gen diff swap
will a 4th gen rear end bolt in my 90 RS? If so, is stronger than the 91-92 Z-28 8.5?
Old Oct 27, 2005 | 10:59 AM
Yes.
It will make 3rd gen wheels stick out about 1-3/4" on each side. 4th gen wheels will fit perfect.
There is no such thing as a 91-92 Z28 8.5" rear. However, the 4th gen rear is the same "strength" as the rear that DID come in 91-92 Z28s, which is the 7.5".
Old Oct 27, 2005 | 11:32 AM
Car: 1990 RS
thanks for the reply. i was told that the 91-92 Z's had an 8.5, i didn't otherwise. my next question is, will the 7.5 hold up to my next motor which is a balanced 355 w/ Vortec heads, hypereutetic pistons, comp cams xtreme energy cam 268h .477/.480 lift, Edelebrock Performer Vortec intake, and an Edelebrock 600 elec. choke carb. approx 325 hp @ the flywheel.
Old Oct 27, 2005 | 12:10 PM
i was told
That's OK, now you know the real deal.
As far as "will it hold up", that all depends on how you drive it. I've personally grenaded these rears with a 305, and the S truck guys (same rear) do so regularly with a 6-cylinder. On the other hand, I also have made one last pretty good behind a helluvalot stronger 400 than that 350 you're talking about. So that part is all up to you, the driver.
draco
Oct 4, 2015 09:25 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
