th350 dead... t56 swap?
Old Oct 30, 2005 | 08:00 PM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
my trannys now dead and im thinkin about puttin in a t56 casue i like the 6 spd idea. how hard is this to do? how about like a ttl cost? will pedals from a 4th gen fit? i have an 85, what about a parts list? can i use the same drive shaft? how about the yolk? crossmember? so ill need a bellhousing,cluchplate,throw out bearing, pressure plate,clutch fork,pedals,slave/master cyl. and of course, the tranny, is that all??? thanks guys later
Old Oct 30, 2005 | 08:12 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
lots of topics on this, stock driveshaft will work, you need a new crossmember tho, either custom made, or one which was specially made for this idea, i think www.skulte.com has one, they also have details on the 6 speed swap.
its pretty much a direct bolt in.
i think the 4th gen will fit but, if i remember correctly you have to removed the gas pedal from the brake or becuase they are attached, i forget. 3rd gen's are easier to put in.
Old Oct 30, 2005 | 10:17 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
The 6 speed bolts right into 3rd gens?
Old Oct 30, 2005 | 10:19 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Aside from the previously mentioned crossmember and the hole you have to cut/widen in the tunnle for the shifter, yes
Old Oct 30, 2005 | 10:24 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah you need to cut 2" more back, where the shifter sits, but yeah it does bolt right up
Old Oct 30, 2005 | 10:36 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Dang fella's thats good news I had no clue the only modification would be around the shifter.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
