Aftermarket Master & slave cylinders? Stock P/N?
Old Nov 5, 2005 | 06:44 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
I just got a hold of a NWC T5 and they guy said he didn't have the master or slave cylinders for the clutch. I was looking on Jegs and Summit and notice that Wilwood brakes has small multi-purpose master cylinders, and has a slave cylinder. What I want to know is can they be made to fit our cars or do we have to use the master/slave cylinders that came in our cars??
Is our clutch fork a "push" or "pull" type when it comes down to the direction the slave cylinder moves the fork.
Also does anyone have P/N for the clutch master cylinder and slave cylinder, and any hoses that run between them?? i order the CD from F-body cd, does that have it on them??
Thanks for any info!!
Old Nov 5, 2005 | 07:58 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Go to advance auto parts and get the replacement slave they stock. It's aluminum instead of plastic and has a bleeder screw. No more flex and it's got a good pedal feel. For the master get whatever stock replacement you can find, or you can get a billet adjustable one from McLeod Ind. for an LS1 car, the master cyls are the same from 82-02. For the line, get a braided line from GM for a 93-02 car instead of using one for/off a thirdgen. They're plastic. The braided line will give you a better pedal feel too. The adjustable master will let you adjust the release point.
1992 Trans Am
May 10, 2023 07:19 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
