Shift Kits
Old Nov 12, 2005 | 05:58 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Shift Kits
Hi Everyone
First of all I have an 89 IROC 350TPI and an 89 RS 305 TBI Camaro. The RS isn't running but has a rebuilt 700R4. The IROC's 700R4 is slipping, I have to give it gas gently or else it will slip badly.
I'm going to have a shop swap the rebuilt tranny into the IROC.
What should I be aware of? If I were to add a shift kit to it, which would you recommend?
Old Nov 12, 2005 | 06:00 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
B&M and transgo are the 2 most common brands. Most sem to prefer transgo. I have been using the B&M for years and like it.
Old Nov 12, 2005 | 07:58 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Do you have a P/N and/or place to purchase the B&M kit?
Old Nov 12, 2005 | 08:31 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
If the shop can't get a kit for you I would go elsewhere. You wanna go somewhere that has done one before. The tranny shop I used around here stocks transgo's, thats how often they install em. www.bmracing.com
Old Nov 12, 2005 | 09:43 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the tv cable will be different and the speedo gears are most likely different. like 85z28guy said, if the shop can't get it for you, go elsewhere. i have the transgo kit and love it. both it and the b$m can be bought through summit if nothing else.
Old Nov 12, 2005 | 11:09 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Thanks for Help Everyone
As you can probably tell this is all new to me. I thinking of either the B&M Shift kit level 2 or the Transpak level 2.
If I'm reading this description correctly with the Transpak you can downinto low at speeds above 15 MPH. Will that hurt the transmission or maybe even the motor by pushing the RPM way up.
Just wondering.
Old Nov 13, 2005 | 12:05 AM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
I've heard nothing but good on the transgo kits. The only way I would ever manually downshift a tranny is with a full manual valve body.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
