U-Bolt for Clutch Master Cylinder
Old Nov 14, 2005 | 09:58 AM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
I'm collecting parts for my auto-man swap. How important is that u-bolt that holds the clutch master cyl. on? Looks like I can use two bolts -
Also, how hard are the resevoir brackets to come by? I plan on buying the whole hydraulic setup new and I know these two parts don't come with it.
Old Nov 14, 2005 | 03:45 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I am in the process of collecting parts for TKO swap from an auto. You can still purchase the u bolt from GM pn 12568902 which I got. It makes it easier to bolt together over standard bolts & nuts. I plan to fabricate a bracket for the reservoir, since it is discontinued new from GM.
jimmy_mac's Avatar
The ubolt probably keeps the stresses be distributed across the whole body of the master cylinder. If it wasn't there the stress would be confined to those plastic tabs the bolts go through. Those may not handle that much pressure and break. The force of your foot pressing the clutch in and the reaction of pressure the master cylinder is developing is probably enough to crack those little tabs.
As far as resevoir brackets go, I have one stock. But when I put a new master cylinder assembly on after my old one wore out, I forgot to run it up under the brake booster and did not want to go through the hassle taking everything apart again and re-routing. So it is zip tied nice and tight to the windshield wiper motor. LOL.
FormulasOnly
Jul 23, 2018 08:47 AM
camaro1185
Oct 26, 2015 06:51 AM
meeklay812
Oct 1, 2015 03:46 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
mfp189
Sep 27, 2015 09:25 AM
