Tranny problem!
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Tranny problem!
hi, I have a driveability problem with my car, and mainly I can't do a burnout. If I hold the brake and floor the car in 1st it will revv up to 1000 rpm and stay there, bog down a bit.
I used to be able to do some serious burnouts without even touching the brake, now I can't even do it with holding the brake.
Also, I've messed with the TV cable and sometimes the car fells good after about 1500 RPM.
I have a 3.23 rear end from a camaro in my firebird and I am wondering if I have some problems with it.
ALso, sometimes I hear some a bit of grind (very fast and subtle from my left rear tire.
What do you think the problem is???
Anyone!?!?!
I am thinkiing my torque converter is out! But it might be ignition related.
I am really out of ideas!!!
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
Whats the odor and color of the tranny fluid? Also did you adjust the TV cable after messing with it? If not you might have roasted the trans.
I set it up just like they explained in the tech article. It shifts fine and firm, and it downshifts no problem. It works great if you ask me, but I am really no tranny expert.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
