no hope for my rear?
Old Nov 15, 2005 | 03:09 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i had a guy take a gander at my rear end recently, because it makes a loud humming sound whenever i hit the brakes. he told me that the sound is the axle bearings, because they are very old.
he also told me that the rear cannot be worked on because the clips, or 'pins' as he said that hold the axle together, were ruined, and had broken off on the outside of the rear? he said he tried to drill out the pin, but he couldnt do it. he said the only way for the rear to come apart is for that pin to come out, if i cant get it out, the rear is hopeless to ever be rebuilt, unless i cut off the axles. does this makes sense to anyone? i thought c-clips were on the outside of the rear, not INSIDE of it. it sounded weird to me, please someone explain this to me.
Old Nov 15, 2005 | 03:19 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Ten-bolt? The C-clips are inside the housing. A single bolt holds the cross pin in place (without removing these two pieces, the C-clips, and consequently, the axels can't be removed). This small bolt is famous for rounding or breaking. I'd think any reliable mechanic complete the job.
JamesC
Old Nov 15, 2005 | 03:34 PM
bigchief's Avatar
ohhh ok, well that clears things up. well, i guess ill just throw in the other rear that i have which is from an 88' formula. i hope the pin on that one isnt broken. have you ever heard of c-clip eliminators?
also is driving with the clips the way they are right now dangerous at all???
Old Nov 15, 2005 | 04:02 PM
JamesC's Avatar
With the C-clips in place the axels can't be come out--unless a catastrophic failure of some sort occurred--so in that regard all should be well. Before you swap, you might take a look yourself. Check these links and do a bit of research:
https://www.thirdgen.org/techbb2/sho...ross+shaft+pin
https://www.thirdgen.org/techbb2/sho...ht=cross+shaft
JamesC
Old Nov 15, 2005 | 04:53 PM
bigchief's Avatar
hey, thanks a lot man, i really appreciate your help
eightsixseven
Dec 16, 2024 01:50 PM
draco
Oct 4, 2015 09:25 PM
neekolzun
Aug 24, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
