Which trans for which car?
Old Nov 17, 2005 | 08:44 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Ok just looking for your opinions on what trans i should put in what car.
I have a TH350C, 700R4 and a powerglide as a backup trans. Also have a set of 3.08 and 4.11 gears.
First car is the one in my sig, ill be using it as a daily driver and plan on doing a long roadtrip next summer. I figure the new motor should be putting out around 350-400 HP. So max reliability is needed here. I want the 700R4 in here but dont want to spend a small fortune to make it bulletproof, and i figure the 350C i will keep my really crappy gas mileage.
Second car is also an 84 Z28 but it will be gutted and will be my weekend trash and bash car. Motor will most likely be in the -300HP range.
What is needed to make the 700R4 handle 400HP being reliable and somewhat cheap?
Old Nov 19, 2005 | 08:25 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well it all dpeends on how much work you wanna do and how much $$ you like to spend
sounds like ou dont want to spend much
so in that case you better just stick one or the other trans in without spending on having it built or anything
what length is the th350 ? how long is the th350 tailshaft housing ?
6" ?
9" ?
what trans was in the car ?
if you plan on no highway driving in the car then go for 4.11
other wise go with 3.08
but then make sure the engine has parts in and on it for higher RPM performance, if you just want to have fun with it anyways
good luck
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
3rdgenparts
Aug 6, 2015 09:03 AM
