Changing rear gear- need help
The car--'92 Camaro RS 305 TBI.
I'm not sure what gear I have, I think it's around 3.20 ish?
I would jack up the car and rotate the wheels and look at the driveshaft to get a good guess, but my car is so low it's a pain in the a$$ to do that.
So dose anyone know what gear I have?
I want to get a 4.10, what do you guys think about that?
Will it be to hard on the motor while on the interstate?
If so I have no problem getting the 3.73
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
First, the only way to tell what gear you have is to open the cover and count the teeth.
I almost got a 4:10 gearset, but opted for the 3:73 instead and I am very glad I did. I went from a 2:73 to the 3:73 and the difference was night and day. In fact for the stock motor, which peaked at 4500rpm, 3:73 was in my opinion, too much gear. a 3:23 would have done it. But I had other plans and the stock 4500rpm's were not part of it.
Thanks for the reply!
I plan on keeping the stock 305 in the car untill it dies.
I really like the 'quick' 4.10 when used with a built trans w/shift kit, which I have, do you think the 3.73 would be better with the stock 305?
Thanks....
Thanks....
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
From the factory it should have came with 3.08 on the manual and 2.73 for the auto. You could check the RPO codes to see if it was ordered with different gears. But in the end the only way to know 100% is to pull the cover and count teeth.
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I would go with a 3:42 or a 3:73 if you plan on leaving the 305 stock. 3:73 is nice. Headers and an American Thunder Exhaust system would wake it up with 3:73's.
EDIT: The rpo codes are on the bottom of the lid for your center consol. Look the codes up on this site.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Theirs usually a sticker under the lid of the console which will have a whole sh!tload of 3 letter/number combos. Those are the RPO codes. Basically all the options that were put on the car, from paint and trim color to interior detailing.
If you still have the sticker there look for these:
GHO
GH2
GH3
GH4
GK9
GL3
GM1
GM3
GM8
GQ1
GS4
GT4
GT5
GT7
GT8
GU1
GU2
GU4
GU5
GU6
GV2
GV4
GV8
GW4
GW6
GW9
G44
HO4
G72
G75
G80 <--- posi
G92 <--- obviously its the G92 package
HA3
HC4
HC7
HC8
HE3
HF7
HF8
HK9
Those were GMs rear axle ratio RPO codes, if you can find any of those let me know, i can tell you which gears were originally in the car.
GHO
GH2
GH3
GH4
GK9
GL3
GM1
GM3
GM8
GQ1
GS4
GT4
GT5
GT7
GT8
GU1
GU2
GU4
GU5
GU6
GV2
GV4
GV8
GW4
GW6
GW9
G44
HO4
G72
G75
G80 <--- posi
HA3
HC4
HC7
HC8
HE3
HF7
HF8
HK9
Thanks bro
I have now---
stock 305
3" no cat with Flowmaster
rebuilt trans with all the goodies
Spohn front/rear sway bars
Spohn lca and panhard bar
Eibach springs
all bushings are Spohn
headers are going in the same time as the gear...
I have now---
stock 305
Eibach springs
GHO
GH2
GH3
GH4
GK9
GL3
GM1
GM3
GM8
GQ1
GS4
GT4
GT5
GT7
GT8
GU1
GU2
GU4
GU5
GU6
GV2
GV4
GV8
GW4
GW6
GW9
G44
HO4
G72
G75
G80 <--- posi
HA3
HC4
HC7
HC8
HE3
HF7
HF8
HK9
GHO
GH2
GH3
GH4
GK9
GL3
GM1
GM3
GM8
GQ1
GS4
GT4
GT5
GT7
GT8
GU1
GU2
GU4
GU5
GU6
GV2
GV4
GV8
GW4
GW6
GW9
G44
HO4
G72
G75
G80 <--- posi
HA3
HC4
HC7
HC8
HE3
HF7
HF8
HK9
I didn't know they were even there
I never looked in the trunk...............geez
GU2 is the code for 2.73s
Considering that and my rpm's reading 2 g's at 70 mph I think i'll go with the 3.73 gear.
Thanks again fellas
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Originally Posted by Trailboss3
Anybody know what a GQ1 code is? My sticker just says "Rear Axle - Standard"
COTM Editor
DON'T MESS AROUND GUESSING WHAT RATIO YOUR REAR IS BY ASSUMING THAT IT IS STILL STOCK. I DID THIS AND FOUND THAT MY 3:42S HAD BEEN REPLACED BY 3:08S BY SOME PREVIOUS OWNER. MY CAR SAT ON A HOIST FOR A WEEK. WHILE I PAID OVERNIGHT SHIPPING TO GET MY GEAR SET BACK TO THE SUPPLIER, AND PAID OVERNIGHT CHARGES TO GET THE CORRECT GEAR SET TO ME. THE WHOLE TIME MY BOSS IS SCREAMING BECAUSE HE IS LOSING MONEY CAUSE WE CAN'T USE THE HOIST. PULL THE COVER AND COUNT TEETH, ITS WORTH IT.
I can't remember starting this thread, I guess I was getting deep into the 30 pack when I posted it ................ Oh well.............
