Converter/stall
Old Nov 20, 2005 | 06:20 PM
Jeffluke's Avatar
Car: 90 L98 IROC/87 LB9 NM5 1AZ / 96 TBI 350 700R4 XCAB S-10..LT1 SOON
Engine: L98/LB9/LT1
Transmission: 700R4/WC-T5
Axle/Gears: 3:73
Converter/stall
I THINK THAT YOU ARE RIGHT W/THE 30 SPLINES, AS I REMEMBER REBUILDING THE 700 IN MY 90 L98 CAR AND THERE WERE TWO CONVERTERS, EARLY AND LATE BASED ON SPLINE COUNT, AS FOR THE V6 VISE V8 THE YEARS ARE DIFFERENT, YOU HAVE TO TRY ONE OF EACH TO SEA WHAT YOU HAVE, I WOULD SAY THAT THE HOT CAM W/OUT THE HIGH RATIO ROCKERS STILL CRAVES A MINIMUM OF 2K OF A STALL I WOULD SAY, BUT IN YOUR CONFIG I WOULD DETERMINE MY USE OF THE TRUCK AND BASE THE STALL ON THAT, AND WHAT GM WOULD SAY AND YOU CANT GO WRONG.
Old Nov 20, 2005 | 09:56 PM
brutalform's Avatar
I think you clicked the "post" instead of "reply". Also, caps are on.
Old Nov 22, 2005 | 11:56 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
lol
i think i know what thread this was meant to be in RE: of
90 year 700 would be 30/27 spline(inpput/output)
