B&M th350 bracket pics/instructions
Old Nov 22, 2005 | 10:56 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Does anyone have installed pics of this bracket? I have seen the hurst installed, but have never seen this installed. if someone has pics or instructions post them up. Im trying to figure out if Im missing a peice all I have is one large bracket with the torque arm mounts held two it by another smaller bracket. How does this bracker allow you to use the stock 700r4 crossmember and tranny mount location?
Old Nov 23, 2005 | 12:10 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
This is what I have...
Am I missing any parts?
Attached Thumbnails B&M th350 bracket pics/instructions-b-m-bracket-pic.jpg
Old Nov 23, 2005 | 01:57 AM
CrazyHawaiian's Avatar
Car: too many ...
Well, I've never installed the B&M one, but I imagine it would work the same as the Hurst kit. Those three holes on the right should line up with the bolts that hold the tailshaft on the tranny, and the actual torque arm mount should line up to accept the torque arm. Now as for the crossmember, I have no idea. My Hurst kit was supposed to come with brackets for the crossmember, but it didnt. And I didnt know it was supposed to come with those brackets so I didnt return it (slaps head).
Old Nov 27, 2005 | 10:01 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Anyone have a pic of the B&M installed, or at least know if Im missing any parts to it in order to make it work.
Old Nov 28, 2005 | 07:06 PM
iroczguy's Avatar
the b&m kit has a plate that extends the transmision mount rearward from the trans to mate to the crossmember
like this one b&m bracket
Later,
Greg
Old Nov 28, 2005 | 10:30 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Crap....
So do I need that peice with the two threaded studs coming up out of it in order to use this kit?
Old Nov 29, 2005 | 03:34 AM
Car: too many ...
That piece would be for the crossmember. If you dont have it you can run an aftermarket crossmember (spohn makes one), or a OEM crossmember from a early 3rd gen 200R4 car (supposedly). The TH350 transmission mount bolt is in a different location from the 700R4, so the stock 700R4 crossmember won't work. I would try to get that missing bracket...
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
