Which rearend will work with a 305 TBI?
Old Nov 28, 2005 | 10:42 AM
drews91maro's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I'm looking to upgrade my rearend to a posi trac/disc brakes rearend. I wanna stay used, like something from a 87-92 Z28. But I was wondering, anybody know if the rearend out of either 4th gens will bolt up? I plan on lowering it and upgrading the brakes...So why not put in a new rear...
Old Nov 28, 2005 | 12:19 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
if you were going to get a better rear end then i would get the 4th gen rear. Yes it bolts right up, the 4th gen rear sticks out 2 inches more on both sides. Your rims are going to stick out more then it is now. I was going to keep my 89 rear end but it was going to cost well over 1G to make it posi/disk and better gear ratio.
Also do a search, there is tons of information out there. Good luck
Old Nov 28, 2005 | 02:04 PM
Car: 91 RS Camaro
Engine: 305 TBI
Sweet guy thanks! There is TONS of info! So you put a 4th gen on yours? Are the Lt1 and Ls1 rearends the same?
Old Nov 28, 2005 | 02:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Very similar but not the same. The LT1 rears are a touch wider (less than .5" IIRC") and the LS1 rears had better brakes. Either will work fine but as mentioned above you will have to live with your wheels sticking out. Either that or get new wheels with the rears having 4th gen backspacing. The emergrency brake is not direct hook up as well. A few more searches will tell you what you need to do there.
Old Nov 28, 2005 | 02:29 PM
Car: 91 RS Camaro
Engine: 305 TBI
is a 4th gen rearend neccesarily better than a 3rd gen say out of a 91-92 Z28?
Old Nov 28, 2005 | 06:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Other than brakes no.
Old Nov 28, 2005 | 06:38 PM
Car: 91 RS Camaro
Engine: 305 TBI
aight cool...off hand you know how hard it is to put the ls1 brakes on the 3rd gen z28 rearend? Any links?
Old Nov 28, 2005 | 07:12 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Im not sure about putting LS1 brakes on a 3rd gen z28 rear. You would just have to look around to see what the deal with that. I have not yet put mine in but i wouldnt have gotten it if i didnt know some good info on the 4th gen rear. Listen to Shifty he knows he's stuff for sure.
Old Nov 28, 2005 | 09:15 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Look in the brake board for "LS1 brake swap". There are tons of threads that will help you out.
Old Nov 29, 2005 | 07:27 AM
Car: 91 RS Camaro
Engine: 305 TBI
Yeah there is tons i'll continue to do alot of searching...thanks alot guys!
pimp2303
Jul 27, 2017 02:03 PM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
MENINBLK
Aug 5, 2015 11:58 PM
