Stock gear for 89 tpi 5spd.
Car: 1989 Pontiac Formula
Engine: 305 tpi
Ok Ive been searching for a long time now to find out what stock gear that 5spd equipped 89 formulas came with, so if any one knows drop me a line thanks.
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Stock gear for 89 tpi 5spd.
to tell if you have a borg rear creep under the car and if you have a plug in the diff cover and the bottom of the center section will have the borg warner insignia.
the borg 3.45 gears are hard to find. cocaclakid recently mentioned he has hte info to get replacement gears from austrialia.
Miles "might" have a set recently come thru. he sells all the stuff for 9 bolts. also if you pull the diff cover and roll the ring gear around that will tell you the ratio as well. if you still have your RPO sticker in your console that will tell you also with the GM3 code for 3.45s.
GU6 is the 3.42 code.
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Originally posted by n8sz28
what is the difference between the standard t-5 and the opt. G92 t-5?
Iroc8t8
May 4, 2026 08:09 PM
hectre13
Aug 26, 2015 08:17 AM
Sanjay
Aug 12, 2015 03:41 PM
dhonda200
Aug 11, 2015 11:50 PM
