automatic downshift question?
Old Nov 23, 2005 | 11:40 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
is there anyway to make a 700r4 downshift faster? rather than when you floor it you have to wait and then it finally shifts. also if you downshift manually with a b&m shifter how do you make it downshift faster.
Old Nov 24, 2005 | 01:41 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The simple answear is to buy a manual. The auto in automatic means exactly that. You can shift it manually thru the gears, but thats not really good for the valves in the tranny. They werent really designed to be opened and closed constantly.
Old Nov 25, 2005 | 12:05 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Nice thing about a mechanically controlled trans is that with the addition of a quality shift kit, itll downshift in a matter of milliseconds to the lowest permittable gear. Youd have a hard time beating the downshift times with a stick.
Old Nov 25, 2005 | 12:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Good thing all the valves stay perfectly stationary when the transmission shifts itself.
Old Nov 25, 2005 | 01:20 PM
dankhound's Avatar
Car: 91 RS
I was speaking about the manuel vavle that controls gear selection. P,R,N,D etc. In automatic shifting that valve doesnt move at all. But when you shift it manually it does.
Old Nov 25, 2005 | 03:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd be doing a whole lot of shifting before you ever wore out the manual valve.
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
69 Six Pack
Oct 5, 2015 07:51 PM
someone972
Aug 30, 2015 12:52 AM
redmaroz
Aug 16, 2015 11:40 PM
