Eaton Differential
Old Nov 29, 2005 | 08:24 AM
FBoDyV85's Avatar
Car: 89 IROCZ Camaro
Engine: 350 w/ Boltons
Eaton Differential
Was wondering i have an 89 camaro that has a regular rear end .. 2.73 gears. Would this differential bolt up to my existing setup? https://www.justdifferentials.com/st...cat=172&page=1
Thanks for your help!
Steve
Old Nov 29, 2005 | 12:48 PM
It might.... you have an 89, which has about a 80% chance of having 26-spline axles. Only a few 89s got the new style rears.
If I was you, I'd pull an axle and check, BEFORE ordering parts, pulling the axles, and THEN discovering it won't work.
Of course, if it was my car, and I just up and ordered a 28-spline part, the rear would FIND A WAY to make itself 26-splines; and vice-versa. Just the kind of world I live in. So I always look at stuff before I buy, try to catch it in the act, so it can't make itself wrong for me.
But who knows, your luck might be better than mine.
It CERTAINLY will not work with your existing 2-series gears. You have 2.73s, and as that clearly states, it's for 3.23 and up. 2.73 is not in the range of 3.23 and up.
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Nope, you'd need a series 2 carrier.. You have 2.73 gears... If you stepped up to 3.23 gears, you could use that unit.
Old Nov 29, 2005 | 05:57 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
No for the reasons in the previous Post and you might have 26 spline axle shafts. 89 was a change over year, but that 2:73 ratio had good chance of havings the 26 spline shafts even into 1990.
dbrochard
Jan 28, 2016 08:42 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
dbrochard
Sep 19, 2015 08:13 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
