9 bolt carrier rebuild q's
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I am rebuilding another carrier from a 9 bolt borg warner 3-series. The friction cones in this carrier have been worn past what the tech threads say are redeemable by milling the ends.
My question is why is it unuseable. if a small amount was milled to ensure a flat surface, then 1 solid shim was used (instead of many small shims)why wouldn't it work? the end of the friction cones and carrier would both lie against a flat surface.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
