Why did Gm switch from 7.5 to 7.625 Rear End
Old Dec 7, 2005 | 10:52 AM
ck76239's Avatar
Car: 1982 z28, 2007 Silverado
Engine: 350 Chevy, 10-1 CR, Comp Cams 270h
Transmission: Th350,
Hello, I've obtained from the junkyard, a 7.625" 10 bolt rear end w/ limited slip and .308 gears...
This will be replacing my ill .273 open 7.5" rear end...
Why did GM increase from 7.5" to 7.625" ??? Did they find the 7.5's were too cheap and weak, and had to add some strength back in???
I'm not making the kind of power that would break either one, just curious...
Thanks!
Old Dec 7, 2005 | 11:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It probably had nothing to do with strength, since they're identical in everything except actual gear size and the gears aren't the weakest part.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
