Gear Ratios
Old Dec 9, 2005 | 03:22 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Gear Ratios
I have tried finding the code on my rear-end for what gear ratio I have, but it CAN NOT find the casting code anywhere! Im 90 percent sure I have a 3.27 gear option.
If it help its an 87'
Shifts into 2nd at 36 mph at about 5k rpm
shifts into 3rd at 75~ mph at about 5k
Old Dec 9, 2005 | 03:42 PM
ede's Avatar
ede
pull the cover and look. you're wasting your time looking for a code, all that'll tell you is what it left the assembly line with not what it has after 15 years or so.
Old Dec 9, 2005 | 03:44 PM
Sounds like your tach reads WAY WAY HIGH.
Only way to know what gears you have is to take off the cover and look.
If you haven't changed the fluid lately, it needs it needs changed anyway. Easiest way to change it is to take off the cover. Look at the gears while you're at it.
Old Dec 9, 2005 | 03:57 PM
What do you man it read high. Those numbers are at wot and what mph the shift points are at. Btw the gear oil is brand new.
Old Dec 9, 2005 | 03:59 PM
High = reads higher than actual
OK, if your gear oil is new, catch it in a clean can and re-use it.
Only way to know what your gear is, is to look. All else is just a guess. Some guessing methods (tach/mph, count drive shaft turns, "codes", etc.) are less accurate than others; none are really accurate.
Old Dec 9, 2005 | 08:02 PM
Is there a place online that converts rpm and mph into a formula to figure gear ratio?
Old Dec 9, 2005 | 08:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yes.
Drumroll please.... It's on this website.
Main tgo page, not the forum, go to equations. That'll get you close enough, but you should be able to find a stamp on the back right axle tube... or on a tag on the pumpkin. If those aren't there, then it's probably not stock so...
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
