YOKE Removal, And bearing replacement,
Subscribe
Dec 9, 2005 | 10:58 PM
Is it gonna be hard to remove the yoke on the differential, or should it be as simple as taking off the nut and pulling??
i just spent $25.00 on fluied and limited slip additive just so i could see it slowly start to drip back out.. so tomorrow i will go to auto zone and get just new bearing and seal,.hopefully this will solve my whinning noise??
if it does not then i will assume that when it went dry and fryed some thing inside right,.,.
or am i just wasting my time and its to late??????????
Reply 0
Dec 10, 2005 | 04:40 AM
only the front bearing on the pinion will come out after removing the nut. if you have noise you need to inspect all the parts. pull the axles, carrier, and pinion and look everything over.
Reply 0
Subscribe
