Tranny problems
Old Dec 16, 2005 | 12:00 PM
Elite ATV1's Avatar
Car: 99 Caviler
Engine: 4. cyl.. :/
Transmission: 5 speed/stock
Tranny problems
today me n my bro where in his camero n when we got back home his gearbox was messed up he would put it in reverse n it wouldnt move but the reveres ligth were on then he put it in neatural and the car moved forwards like it was in drive.
heres a pic of his car if you can help reply back to me with any advice
Old Dec 16, 2005 | 12:16 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Sounds like the shift cable is out of adjustment or bad. Try disconnecting the cable and manually turning the manual shaft on the trans and see wat the result is. If it clicks into gear and moves then the trans is good and the cable is bad or out of adjustment.
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
