New 7oor4 Not Acting Right Please Help
Old Dec 16, 2005 | 04:23 PM
PROJ91's Avatar
Car: 91RS
Engine: 383
I am not ready to dog on the company yet but I have some concerns with this new transmission.
When in the overdrive position the tranny shifts pretty good fairly smooth. The problem is when I select the gears my self or use 3rd. I have a real distinctive clunk with a space in between when it shifts up or down from 2-3 3-2. I am trying to find out as much as possible about this condition before I call them back on this issue so they do not blow too much smoke up my rear. It also has a condition where it does not always like to hold 2nd. Sometimes when manually shifting into second it will either not go or act like it hit neutral, if I stab the pedal it will usually go but that aint right. I would just yank it out right now but the shipping cost back and forth are going to kill me ( I believe this is inevitable anyway) I just don’t want to do it yet. Is anyone here familiar enough with these trannys enough to know what may be going on? All of the pressures were checked when it was installed and were good to go.
ANY INFO WILL BE APPRECIATED
Old Dec 18, 2005 | 06:31 PM
AZZ28's Avatar
Car: 1990 IROC
Engine: l98
Two things: 1. You should be carefull when talking to the company because if they know you were manually shifting the tranny they might void any necessary repaires/warranties. 2. From what I have been told you should not be manually shifting anyway. When you are between gears the line preasure will drop and it will slow your shift. In my opinion for best performance and reliability you should always keep the tranny in overdrive.
Old Dec 18, 2005 | 06:42 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Check your warranty. They may pay a local shop to fix it rather than ship it back. It sounds like it could be a problem with the valve body. Shifting a 700R4 manually wont hurt it, especially if you have a shift kit installed.
Old Dec 19, 2005 | 01:53 AM
StaticVertigo's Avatar
heh. In the hell are you talking about. Manually shifting is bad? Psh. higher the rpm = higher the line pressure. higher line pressure allows for less slipping when each reaction member is applied. I.e. one way clutch, clutch pack or a friction band. more line pressure means faster firmer reactions.
Why do you think the vette servo makes a difference? the surface area is greater allowing more force to be distributed over the servo.
Old Dec 19, 2005 | 01:56 AM
anyways. I think this might be more of a linkage problem, and the clunk you hear might be caused by someone leaving out the anti-clunk spring when they rebuilt it ..*yes, im being serious. it has an anti clunk spring"
Old Dec 22, 2005 | 01:09 AM
AZZ28's Avatar
Car: 1990 IROC
Engine: l98
I was simply referring to a sort of all out, or straight line acceleration. In this situation a properly adjusted tranny will shift at the same point the driver would manually, consequently " higher the rpm = higher the line pressure" is not relevant. I do not know nearly enough about trannys to tell you your wrong, but in my opinion a mild car with a mild tranny and a stock shifter is going to get itself through the gears and down the track quickest, shifting on its own.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
