stuck at 1000 rpm???
Old Dec 17, 2005 | 12:02 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
When I powerbrake and floor the car, no matter which gear, I stay at 1000 rpms. Than I let off the gas and car idles funny.
I was wondering if my TCC is locked up all the time and what can cause this 1000rpm lock!?!? The transmission shifts fine, and there are spots where the car is slow. (If I slow down to about 20-25mph and give it gas, the car barely picks up, and if I go any lower on the pedal it downshifts and goes fast again.)????
I need some help... I exhausted my options (except the fuel pump)..
Old Dec 18, 2005 | 07:17 PM
Anyone has any answer to this??
Old Dec 19, 2005 | 02:02 AM
StaticVertigo's Avatar
so its sluggish in low rpms? what made you think this was a tranny problem? i need more info
Old Dec 19, 2005 | 07:54 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Prolly lost one of the one way clutches in the trans.
Or the stator and impeller are eating each other in the converter.
That would cause a functional trans to do low rpm burnouts. One or the other is what ate mine after my vortec head swap :-)
If it has always done this, there is the possibility u got some low stalled converter from another app, but if its at 1k rpm, I doubt it.
later
Jeremy
Old Dec 20, 2005 | 01:17 PM
I can still burn rubber if I don't hold the brake! ITs a bit sluggish, but if I were to let it roll 5mph than gas it, the car takes off like it used to from a 0.
Would there be a possibility that I am not getting enough fuel when I am powerbraking the car??? Or do you think its the transmission.!?!?
If I were to get a new converter, how hard would it be to install???
IROCtometal
Sep 20, 2015 11:08 PM
ctoledo0834
Sep 18, 2015 04:16 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
