5th gear problem WC T-5
Old Dec 17, 2005 | 12:32 PM
mantiz85ws6's Avatar
Car: 85 Trans Am
Engine: 350 T.P.I.
Transmission: WC T-5
I have a world class 5 speed with about 9000 miles on the rebuild. Just recently when I shift to 5th gear the car shakes really bad any ideas as to what is causing this??
Old Dec 18, 2005 | 12:12 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What speed are you at in 5th gear? Possible causes include out of balance tires, driveshaft, flywheel, or clutch. You could also have a problem with your u-joints or the rear end.
Old Dec 18, 2005 | 09:16 AM
Car: 85 Trans Am
Engine: 350 T.P.I.
I have tried shifting it into 5th at several different speeds and it does it at varying speeds high, med, and low. I have an aluminum drive shaft and 3:27 rear. I'm begining to think it might be my rear end or 5th gear going on it?? I even feel it doing it in 4th gear at lower speeds around 35 miles but not nearly as pronounced as 5th and it goes away as I accelerate. Never did this in the past just came out of nowhere.
junkcltr
Aug 2, 2019 11:12 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
jbd1969
Aug 17, 2015 07:06 PM
