Bleeding the hydra clutch
Old Jan 5, 2006 | 09:13 AM
BlackphantomZ28's Avatar
Car: 1985 Z-28
Engine: 350 4bbl
Transmission: t-5
Axle/Gears: 4.11
Ok guys I need to know how to bleed the hydra clutch on a third gen book says there is a screw to take loose just like the brakes but im not seeing it any hep would be appreciated as i cant drive my car till i get this fixed.
Old Jan 5, 2006 | 11:00 AM
What makes you think they need to be "bled"?
What just happened, immediately prior to this supposed need appearing? You're just driving down the road, everything's cool, and all of a sudden you just developed a burning desire to pull over and bleed the clutch hydraulics; or what?
Knowing that would help point you in the right direction.... which most likely, isn't bleeding the clutch hydraulics.
Old Jan 5, 2006 | 11:40 AM
Car: 1985 Z-28
Engine: 350 4bbl
Transmission: t-5
Axle/Gears: 4.11
Actually I changed my clutch to a zoom HP clutch and when I went to start the car and run through the gears I had no pedal and I looked over everything and it was all aligned and installed right so Im thinking the hydro clutch is out or I need to replace the slave cylinder. Cause I have no clutch pedal or resistance at all.
Old Jan 5, 2006 | 12:32 PM
Most likely, if you didn't break the hydraulics open, then they don't need bleeding. Leave them alone.
Probably you have the throwout bearing on the fork wrong. Here's a link to a post with RB's famous pics of a right and a wrong throwout bearing install. If you put it on th efork like the wrong one, the clutch will do exactly as you describe. So I'd suspect that you have yet another case of that extremely common mistake.
https://www.thirdgen.org/techbb2/sho...hreadid=284924
Old Jan 5, 2006 | 02:25 PM
Car: 1985 Z-28
Engine: 350 4bbl
Transmission: t-5
Axle/Gears: 4.11
Nope man the throwout bearing is in correct I did a clutch on my car like a yr ago but it was just a stock clutch thats why this one is getting replaced and everything worked fine before maybe I dont need to bleed the clutch but just replace the slave cylinder.. I push the clutch and i can see the fork and the bearing push against the pressure plate but the pedal is all the way to the floor like its not pushing far enough to engage disengage the clutch. Cause I cant get the car into any gear but the car starts right up with the clutch pushed in.
Old Jan 5, 2006 | 03:24 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
If the old clutch worked before you changed it, either:
-you installed the incorrect parts
or
-you installed the correct parts incorrectly
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
