shift kit choice?
Old Jan 7, 2006 | 05:54 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
shift kit choice?
i just want to throw a shift kit in my trans when i change the fluid and filter so it will last till i buy a built trans. my question is which kit should i get?
The trans pak
http://www.jegs.com/webapp/wcs/store...0549&langId=-1
or the shift improver kit
thanx for the help guys
Old Jan 8, 2006 | 01:15 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
From what I have heard (not yet experienced - currently installing my kit), the Trans GO kits are the better kits to go with. I think summit sells them. Just a thought - something to look into.
Old Jan 8, 2006 | 02:29 AM
Pro Built Automatics's Avatar
Go to http://www.700r4l60e.com/store/custo...&cat=28&page=1 if you want a "modified" Trans-Go Performance Shift kit that will give you best of both worlds, smooth 1-2 part throttle shifts, and firm WOT shifts. If I can be of help, let me know?
Old Jan 8, 2006 | 01:26 PM
MaNiAk86's Avatar
Car: 1983 trans am
see the thing is guys im not keeping my current trans so i dont want to put much money into it. i can feel thatmy trans is slipping and have been told by a few mechanics that a fluid and filter change plus a shift kit will correct the problem.
Old Jan 8, 2006 | 03:08 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
ill sell you a B&M shift improver kit that i never got around to using. if you just need it to hold up this should be fine, and cheap. let me know if you are interested.
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
