t56, t5 and 700r4 weight
Old Jan 10, 2006 | 01:03 AM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
does anyone know the difference in weight between these three transmissions im just curious
Old Jan 10, 2006 | 02:27 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
t56~700r>t5
Exact weights, no. But I do remember the t56 seemed to weigh just as much as the 700 I pulled out.
Old Jan 10, 2006 | 05:58 AM
CrazyHawaiian's Avatar
Car: too many ...
n/m
Old Jan 10, 2006 | 07:18 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
T5= 75lbs dry
T56= 125lbs dry
700R4= 225lbs dry
TKO 600= 95lbs dry
Old Jan 10, 2006 | 07:19 AM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
This came off of the tech data portion of tgo.
Differential Weights of Accessories
Code Item Weight
MD8 Automatic Trans 101.9 (with 305 & 350)
I have seen it listed several places that the t5 is 100 lbs.
So 100 + 101.9 = around 200 lbs.
Keep in mind this is just a guestimate.
Old Jan 10, 2006 | 10:52 PM
n8sz28's Avatar
Car: 85 camaro z28
the post says the 700r4 ways about 225 pounds does anyone know if it ways this much for sure.
Old Jan 11, 2006 | 02:09 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I could be wrong but I kind of find that hard to believe. I'm a freaking wimp and I lugged that thing below my bird before I swapped it completly out...
I'd like to see proven weights..
Old Jan 11, 2006 | 10:46 AM
z28evans's Avatar
Car: 89 iroc
a 700r4 doesn't weigh 225 lbs
Old Jan 11, 2006 | 11:51 AM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Same here. Id freak out if they weighed that much.
Old Jan 11, 2006 | 03:22 PM
Ricktpi's Avatar
Got that info off the net. Double checked it & found GM lists the shipping weight of a MD8 at 180lbs. If ya don't believe that I can weight the one sitting on the floor of my garage! All I know for sure is they are heavy ****'s.
Old Jan 11, 2006 | 03:51 PM
n8sz28's Avatar
Car: 85 camaro z28
do us all a favor and weigh the one you got lying around Ricktpi and end this mystery weight thanks .
Old Jan 12, 2006 | 08:00 PM
Ricktpi's Avatar
MythBuster Segment 700R4 Weight
Well the ol' Health-o-meter says 140 lbs. This without fluid or converter. Take it for what it's worth.
Old Jan 12, 2006 | 11:27 PM
n8sz28's Avatar
Car: 85 camaro z28
thanks
for
the
info.
Old Jan 13, 2006 | 03:52 AM
Pro Built Automatics's Avatar
I ship them out at 125lbs. dry.
Old Jan 13, 2006 | 06:47 PM
bowtie350_428's Avatar
Car: 84 Z28, 91 Corvette, 94 T/A, 02 Dodge Ram QuadCab 1500
Engine: 350 SBC
Transmission: 5spd
How about the t5 weight?
How about the T5 weight? Is it 75 or 100? I heard it was closer to 100lbs (95 lbs to be exact).
A guy at the UPS Store said that a T5 tranny would have to be shipped freight. Is he full of BS? Can't I just stick the T5 in a box and just say "here ya go..."?
Would $100 - $125 sound right for shipping from S.A. Texas(78249) to Denver CO (80227)?
Old Jan 17, 2006 | 12:03 AM
n8sz28's Avatar
Car: 85 camaro z28
not sure
Old Jan 17, 2006 | 10:53 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
T5 is less than 85lbs dry. I shipped my old one out and that is what it weighed in the box with packing materials.
I had it boxed and shipped from UPS. they put it in a box, used that expanding foam stuff and away it went.
Old Jan 17, 2006 | 12:34 PM
dbtk2's Avatar
Car: 1986 Trans Am
Engine: Carb'd 305
Axle/Gears: 10 bolt, 3:42's
Re: How about the t5 weight?
Its gotta be closer to 75lbs. I am a pretty small guy(5'10"/130lbs.), I've never worked out or anything like that, and I had no problem pulling my T5 out myself when I did my clutch. (I used a trans jack to hold it up while removing the bolts, but I took it off the trans jack and set it on the bench with no problems.) I'd say its right around 75lbs.
Shawn
Old Jan 17, 2006 | 12:51 PM
Engine: 350 SBC
Transmission: 5spd
Thanks guys, that sounds about right. I placed it on a scale and read it at about 75lbs. Just wanted to make sure.
Old Jan 17, 2006 | 09:22 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
mine weighed in right around 80 lbs. with it in the crate i made.
Justin
Old Jan 17, 2006 | 11:26 PM
n8sz28's Avatar
Car: 85 camaro z28
what about the exact weight of a t56? I just bought one and was curious how much it weighed compared to a 700r4 while its in the car with fluid and all!!!!
Old Jan 18, 2006 | 05:17 PM
Zepher's Avatar
The T56 by itself weighs about 125. with the clutch/flywheel/PP/fluids, I would think it weighs about the same as a 700R4 with converter and fluid, about 175lbs or more.
Old Jan 18, 2006 | 08:24 PM
n8sz28's Avatar
Car: 85 camaro z28
thanks
Old Jan 19, 2006 | 09:13 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes, that is how summit ships the mustang t-5 (just a double walled box) simple as that!
Old Jan 30, 2006 | 06:59 PM
drjohn981's Avatar
Car: 86 iroc z28
Transmission: t5
Axle/Gears: 4.10 10 bolt posi
Just got my LS1 T56, with bell housing. Box says right on it that the weight is 143 # (dry).
Old Jan 31, 2006 | 10:44 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
My aftermarket t56 weighs 125 pounds on my Walmart scale.
I picked up a 700r4 from a junkyard it also weighed 125 pounds.
I think the 143 you speak of is with the box.
Old Feb 1, 2006 | 05:46 AM
drjohn981's Avatar
Car: 86 iroc z28
Transmission: t5
LS! T56
Yes, the 143 # was with the box, but it was a cardboard box, with foam and stretch wrap around the tranny. Packing may have weighed 3 #. OH yeah, it also had the hydraulic throw out bearing - another pound?
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
FormulaJoe
Oct 26, 2001 11:39 AM
