no hope for my rear??
Old Jan 12, 2006 | 02:47 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
my dad tried working on my rear recently, just to make sure it was in decent shape, and he told me he couldnt take it apart. a couple of things i want to go over that he told me.
1) "it doesnt have c-clips, it has a pin in the middle of the rear holding the axles together"
2) "i cant get the pin out, usually you just put a magnet in there, and it comes right out after you take out the alen key holding it in, then you can remove the axles and work on the rear"
how is it possible for my car not to have c-clips??? does that mean its not the stock rear? i thought all of these cars came w/ c-clip rear ends. also, does what he said make sense to you guys? have any of you heard that happening? or has it happened to you?
by the way, i have a 1989 firebird formula (had a stock 305 TPI)
Old Jan 12, 2006 | 06:30 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
if it is a ten bolt. then you have to remove the small bolt in the side of the diff chunk so you can remove the big pin, then you have to push your axles in to get at the c clips.
Old Jan 12, 2006 | 11:05 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Re: no hope for my rear??
There is always the buns o' steel workout.....
Sorry, it's late and I'm gettin' a little punchy....
Old Jan 12, 2006 | 11:39 PM
bigchief's Avatar
Re: Re: no hope for my rear??
LOL... dude thats hilarious.
but seriously, are the c-clips very apparent on the rear? like are they very obvious? if so, can you see them if you just lift the car and look at it?
Old Jan 12, 2006 | 11:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
remove the center pin, then push in the axles to reveal the C-clips. unless your car has a 9 bolt borg-warner rear end then it will have no C-clips and the axles bolt in like a ford 9" design. counting the bolts on the cover will clear it up for you.
Old Jan 14, 2006 | 09:43 AM
bigchief's Avatar
thats the thing, he said he cant remove the center pin. its like jammed in there, he said from doing too many burnouts, heating it up and stuff over the years.... it has over 245,000 miles on it if its the original rear end....
waht do you think?
Old Jan 14, 2006 | 10:04 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
waht do you think?
I think that IF the locking pin came out in one piece, the center pin should slide right out. I went through this awhile ago myself - when I still had my 10 bolt rear in it.
My problem was that the pin broke and the last 1/2" or so was stuck in there. Kinda sounds like what you're descibing.
It all starts and ends with the lock pin. If it doesn't come out, there's no way to take anything apart -axles included.
I'll see if I can find the post, and paste it up here. Skyway tools sells an extraction kit just for this common problem. And there's magnets, etc...
Old Jan 14, 2006 | 10:11 AM
Confuzed1's Avatar
Car: 83Z28 HO
OK - here it is. It started out with a vibration problem, so it's a long post. Look halfway down page 2 and you'll see the pin I'm talking about.
https://www.thirdgen.org/techbb2/sho...n&pagenumber=2
Old Jan 24, 2006 | 09:42 PM
bigchief's Avatar
Hye, thanks SO much man!
Old Jan 24, 2006 | 10:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I just finished rebuilding my 10 bolt, and had a fair bit of trouble. My cross shaft also needed a fair bit of nudging. I turned it so the side that has the hole in it, was pointing away from me. Then I hammered the pin into the center section, about 1" or so, just enough that I can still rotate it back. Then once I could get to the hole that the 5/16" pin was in, I just pried it out with that.
I sure hope you used a 6 point box end wrench for that bolt, and heat, there's red loctite from the factory.
Here are the 3 threads I made whilst disassembling my rear end, hope they help.
Old Jan 24, 2006 | 10:53 PM
bigchief's Avatar
most definetly, thanks everyone for all the help once again
eightsixseven
Dec 16, 2024 01:50 PM
draco
Oct 4, 2015 09:25 PM
neekolzun
Aug 24, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
