ls1 / 700r4 ?
Old Jan 12, 2006 | 06:45 PM
onesweetta's Avatar
Car: 1991 T/A
Engine: 305 T.P.I
Transmission: 700R-4 w/shift kit
ls1 / 700r4 ?
does anyone know what/ if it is possible to run a 700r4 behind a ls1 if yes what would be needed as far as elecronics and so on has anyone done this ?
Old Jan 12, 2006 | 08:09 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I assume you mean an LS1 into a thirdgen, will it work with a 700r4? I don't see why not. The 4L60E is electronically controlled versus the 700r4 is hydraulicly operated (throttle valve cable). You'd need to fabricate something on the linkage for the TV detent to work properly... And I have no idea if the TCC lockup is the same signal (but i'd assume so) in both of these transmissions.
That's just my guess.
Old Jan 12, 2006 | 08:25 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
Re: ls1 / 700r4 ?
Egh, your better off just buying the engine with the transmission already in. Honestly, if you plan on modding the LS1 the 700R4 wouldn't hold up, infact, I am just pulling things outta my *** here but they do have a certain limit and the engine's power could cause the 700R4 to wear down alot faster. I wouldn't recommend it. the 4L60E is just much more advanced than the 700R4...it was built to take a beating, it was built for a high performance engine, it was built to last long as well.
If you shop around you can score an engine/tranny combo deal for cheap. Ebay has a few stores that sell them together at a decent price.
Old Jan 12, 2006 | 11:53 PM
Firebat's Avatar
its been done. Go search around in the LTX and LSX swap forum in the Engine Swap forum.
I wouldn't do it unless your 700R4 is rebuilt.
loud91rs
Oct 5, 2015 10:05 PM
6998poncho
Sep 25, 2015 02:56 PM
