700R4 knocking while in reverse
Old Jan 14, 2006 | 10:38 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Well like the title says...it just started knocking about a week ago while being in reverse. It is almost like a grinding/knocking(mixture of the two) noise coming from the front of the tranny or back of the engine, somewhere in that position from the cab...haven't gotten underneath it yet to see what's up. The tranny doesn't do this while in its forward gears though. Its weird b/c its never done that until a week ago and I am not hard on it at all. Any input would be great guys/gals!! Thanks!!
Old Jan 14, 2006 | 11:25 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
first thing I would check is the torque converter bolts and the right (passenger side) engine mount.
Old Jan 14, 2006 | 11:30 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Ok....I will check the engine mount tomm...got to pull the header off anyway. And I will check on the torque converter bolts I reckon tomm as well.
Old Jan 15, 2006 | 09:06 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Anyone else?
Old Jan 15, 2006 | 10:59 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Ok....checked the motor mounts...look good.....checked bolt and bellhousing...looks fine...repositioned the 3 bolt header flange....priceless....no more knocking now!! Did find out that my rear main seal is leaking though!! Oh well....thanks for the help.
Old Nov 6, 2022 | 09:40 PM
TheMagikMan's Avatar
Car: 1986 Firebird Trans Am WS6
Engine: Cammed 358 TPI
Transmission: Built 700r4
Axle/Gears: 2.77 Borg-Warner 9 Bolt
Re: 700R4 knocking while in reverse
I realize that this is a 16 year old thread, but I'm having what sounds like the same issue. To clarify, 3 bolt header flange is your exhaust header, right? What was it hitting?
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
92projectcamaro
Sep 29, 2015 07:07 PM
efiguy
Sep 27, 2015 01:30 PM
6998poncho
Sep 25, 2015 02:56 PM
