9 Bolt rearend
Car: 1988 Chevy Camaro
Engine: 355
Axle/Gears: 3.43
9 Bolt rearend
Check this rearend out I need to buy a new rearend and just wanted to have you guys input about it.
http://cgi.ebay.com/ebaymotors/GM-Fb...QQcmdZViewItem
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
thats a ford 9 inch rear for fbody's. not a 9 bolt.
thats a nice rear..very strong. if you need the rear to handle power then thats a great choice.
that rear also looks like its designed for LT1-LS1 cars which means its a 4th gen rear end.
those rears are about 2 inches wider per side than thirdgen rears, meaning your thirdgen spec wheels will stick out. some say its even with the fender line which dont look too bad IMO. but some other wheels will stick out really far and its not a great look
Car: 1984 z28
Engine: 355
That rear looks very good. Moser components are defenitly good stuff and I don't think you could go wrong. Looks like they might sell quite a few of these. I know moser complete setup minus the brakes are about 2300 and about 300 shipping. You should probably e-mail the company and see if they will build you one for a third gen, since it does look like one for a 4th gen. price should be the same just shorter axles and housing. the 4th gens are an inch and a half wider per side.
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
