How many guys using tremec 5sp?
Old Jan 17, 2006 | 09:22 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
Just a little curious. i am installing a tremec 3550 in my iroc behind a healthy 406. wanted to get some, it's strong as an ox, or weak as a twig stories.
Old Jan 18, 2006 | 08:44 AM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
I've put 467lb/ft to the rear wheels with my TKO. Should be at or slightly above 500 at the engine.
Old Jan 18, 2006 | 09:01 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Axle/Gears: BW 9 Bolt/3.70
485hp / 575 ft lbs @ rear wheels here through a TKO. Tranny is holding up just fine. I do need to fix my synchros as the 1-2 shift is occasionally rough. Mike Fortes told me that this is not uncommon from shifting these 'too fast'. I never have a problem with normal driving... only when the adrenaline is flowing.
There is another guy just north of me running a 3550 behind a 427 BBC in the same situation... no tranny breakage but same issue with synchros.
I am also using a pro 5.0 shifter which was a nice upgrade.
Cheers.
-Schultzy
Old Jan 18, 2006 | 01:47 PM
Car: 87 iroc
Engine: 410 sbc
i'll have to keep that 1-2 shift in mind then, thanks. anybody else??
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
