Removing driveshaft
Old Jan 19, 2006 | 03:52 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Removing driveshaft
What tools will I need to do this. Im swapping my rear out for a posi but havent had the time to go look at it. Is it a simple task? Thanks
Old Jan 19, 2006 | 06:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
remove 4 bolts retaining the rear u-joint, pull out the front yoke out of the trans and get ready for a flood of trans fluid out the back of the trans.
Old Jan 20, 2006 | 12:39 AM
CrazyHawaiian's Avatar
Car: too many ...
Yeah make sure you keep your face away from the tailshaft of the trans when the driveshaft comes out. Last one I took out was somewhat stuck, had to lay a certain way to get leverage (which happened to put my face under the tailshaft) and BAM all in the face when it finally came free. Stupid!! hahahaha
Also make sure you're carefull with the U-joint when the driveshaft is out, if the caps come off all those little pins might fall out, real PITA to put those back in right.
Old Jan 20, 2006 | 01:45 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ya know,
If u have the rear of the car only, jacked up far enought o pull the driveshaft or rear end easily, you shouldnt get anythign on u fluid wise.
Just get it way up in the air safely and u wont have to worry about any leaks.
Course this only counts if u have the parts on hand.
U can pull it from the rear and swing it out of the way on blocks or jackstnad and just tie it up to the car even.
leave it in, just support it and it works too, no messy mess
later
Jeremy
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
