26 spline?
Old Jan 30, 2006 | 04:41 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
26 spline?
I have a 10 bolt 1984 rear I took out. Is it a 7.5 26 spline? Can I put in a new differental. Can this rear be beefed up?I put in a 89 9 bolt 327 put wanted to build a back up. The one laying in my garrage has 308 gears.
Old Jan 30, 2006 | 05:38 PM
ede's Avatar
ede
did you do a search? i think someone else ask the same question.
Old Jan 30, 2006 | 06:16 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Yes I did under "84 rear end" I'll try 26 spline hoping that it pertains to my rear. I did put energy and will again put effort in a search. I never try to waste moderators time.
Old Jan 30, 2006 | 06:24 PM
drjohn981's Avatar
Car: 86 iroc z28
Transmission: t5
Axle/Gears: 4.10 10 bolt posi
3.08 gears use a two series carrier. Anything higher than 3.08 requires a three series carrier.
Old Jan 30, 2006 | 08:25 PM
ede's Avatar
ede
you should have a 7.5 ten bolt with 26 spline axles, 28 spline came out in late 89. the 7.5 and 7.62 ring gear interchange so don't get hung up on that. you can weld the tubes and run a rear brace and increase strength quite a bit. you can swap carriers from any other 7.5/7.62 ten bolt rear and axles as well if you need to.
codeysabatini
Nov 10, 2015 04:07 PM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Numbah-1
Sep 20, 2015 09:31 AM
Prodigious
Sep 18, 2015 05:23 AM
