Picking up some transmission goodies
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Getting a performance rebuilt transmission (by Jimmy's in Mundelein, IL if anyone knows them) and an Edge 3800 lock-up torque converter, and I'm trying to put together an order on Summit for the pieces I want to install with it.
I want to install a trans temp guage (braze fitting into pan when I install the trans), transmission cooler, and transmission blanket.
For the guage, I have ATM-2552 picked out. Its the cheapest analog/electric transmission temp guage that AutoMeter makes.
For the blanket, I'm buying the RCI SFI 4.1 spec nylon blanket. I realize a full transmission shield is the best route, but that is $270 I don't have at the moment, nor will it be required for the plans I have for this car.
Now for a cooler...I can't decide what to go with. I need to keep the price under $47 as the above two items are leaving me with $47 to spend. I can't really wait longer and save more currently because the transmission swap has to happen next weekend.
BMM-70268 is a 7 1/2"x11"x3/4" plate-style cooler by B&M, and FLX-3820 is a 7 1/2"x20 1/2"x3/4" tube-fin-style cooler by Flex-a-lite. Which is going to be the better one to go with? I have plenty of room for either one, as it will get mounted to the front of my radiator (no AC radiator anymore).
From what I understand, the plate-style coolers are more efficient, but the tube-and-fin radiator is much larger. Will the size make up for the lower efficiency? I don't mind if these are a bit overkill as I can make something to block off part of the cooler if need be while street driving and then take it off for max cooling at the track.
Car: 1997 Corvette
Yep, all I've ever heard was good about his transmissions.
Which transmission cooler should I go with that I listed above?
92projectcamaro
Jan 18, 2016 08:00 AM
