trans swap
Old Feb 7, 2006 | 10:05 AM
chiefsmackahoe's Avatar
Car: 87 trans am
Engine: 305 4bbl
Transmission: th700r4
trans swap
will a 4 speed muncie bolt up to an 87 t/a auto?
Old Feb 7, 2006 | 10:32 AM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
yes it will bolt to block but you will have to get a flywheel for a 87 engine if it is a one piece rms it will take a different flywheel than the engine that the tranny came from because it was most likely from a two piece rms and they balance different i dont really dont know about the trans mount or driveshaft muncies i have have 27 spline not sure how many spline your trans has and i belive the muncie is shorter which you will have to get a new driveshaft or have one built and have to get the clucth and brake pedals and the muncies i have both are manual clutches not hyd. dont know if you can convert them to hyd.
Old Feb 8, 2006 | 07:35 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Re: trans swap
With the right bellhousing it will. Mechanical clutch linkage would be the easiest to hook up, but you would have locate all the parts from a 82-83 f body. Hydraulic could be done, but tricky & expensive. A T-5 setup won't work & a hydraulic TO bearing or custom built slave setup is necessary.
Jorlain
Aug 24, 2022 05:11 PM
midge54
Sep 2, 2020 07:13 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
