Rear end swap
Old Feb 15, 2006 | 09:38 AM
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Rear end swap
Hey guys, I'm in the middle of a rear end swap (Standard 8" rear to a stock firebird posi unit) primarily for the disc brake set up and the posi on the new one. My problem is that the original rear end has different gears in it (not actually sure what they are... its from a V6 car) What I want to know is if I can take the gears from the old unit and install them in the new one.. and if they still work with the posi . Any info would be a great help.. Thanks
Old Feb 15, 2006 | 10:02 AM
Never heard of a 8" rear in these cars. Or any GM for that matter. So right there, there's no way we can tell you, until we know what model(s) of rears you're working with.
Once you establish that both rears are at least the same model, then whether the gears will work, will depend on the ratios.
If both rears are 3.23 & up (3 series), or both rears are 3.08 & down (2 series), then they'll swap over; if you know how to do gear setup. If one is 3 series and the other is 2 series, then no they won't. Although, if it turns out you want to put 3 series gears onto a 2 series carrier, you can buy a spacer to do that. However there's NO WAY to put 2 series gears on a 3 series carrier, unless you know where to buy a spacer that TAKES SPACE OUT instead of PUTTING SPACE IN.
Old Feb 15, 2006 | 02:06 PM
neilb's Avatar
Yeah sorry I forgot which rear I have... I really need to check on that.. but thanks for the info I'm sure it wil help
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
