modified 9 bolt diff. cover
Old Feb 18, 2006 | 12:55 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i wanted to improve on the GM design.
5/8-11 jam nut welded over the fill hole
5/8-11 x 3/4" long stainless steel hex head bolt to replace the "rubber plug"
1/2-13 jam nut welded at the bottem of the cover
1/2-13 x 1/2 long stainless steel hex head bolt as a drain plug
then mounted to the Diff. using 5/16-18 x 3/4" long stainless steel heax head bolts.
Edit:well i was going to post a pic but it's too big.
Old Feb 18, 2006 | 11:31 AM
91banditt2's Avatar
Engine: 5.7 HSR
lets try this
Old Feb 18, 2006 | 11:33 AM
91banditt2's Avatar
Engine: 5.7 HSR
and this
Old Feb 18, 2006 | 01:54 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looks good. i was planning on doing something similar this spring as well.
Old Feb 18, 2006 | 04:28 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
when i used to have my 9 bolt, it would always leak from the damn plug. good work.
Old Apr 4, 2006 | 08:36 AM
player 88's Avatar
Engine: 360 .060 over TPI
9 bolt voer mods
nice job on the cover.
Mine has the plug removed with a fill bolt also. Additionally mine has a 1" spacer between the housing and the cover.
It adds addtional fluid capacity for cooling. This was done to car when it won it's class at Sebring, years ago.
I am going to add a drain plug to the bottom of the spacer to make it easier to serivce.
Steve
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
blackd-out z28
Aug 15, 2015 08:18 PM
