Vacuum line to the transmission cable
Car: 1994 Trans Am
Under the hood for the last couple weeks there has been a loud hissing sound. It turned out to be a vacuum hose had split and was all but falling off. I plugged it and the rpms raised a bit and the engine idled smoother and quieter. The hose that was split leads to this little ( I want to say pump) thing by the coolant resevoir and that leads to the TB cable for the transmission right?
I haven't gotten a chance to drive it after I did this as I had company over, but what does that vacuum line do for the tranny? I have noticed crappy shifting and wimpy performance. But only since the hissing started.
Axle/Gears: '01 3.42 10 bolt
700R4s don't have a vacuum line going to them for anything.it sounds to me like you are talking about your cruise control valve. it has a cable going from the throttle body to a disc shaped object on the drivers side right behind the radiator. then, a vacuum hose that goes from there to a threeway vacuum fitting that also connects to the rear passenger side of the upper plenum. there is also a vacuum line that goes from the disc shaped abject to the brake pedal.
Car: 1994 Trans Am
I don't know what it is, but as soon as I hooked it up, the performance came back, the idle went back up, and shifting improved.
performance came back and idle improved because you plugged a vacuum leak. the tranny shifted better because the engine was running better. the next time you drive your car with that vacuum line plugged, see if you have cruise control. i bet you don't. vacuum has nothing to do with the 700R4.
Car: 1994 Trans Am
I know you're right. The way the hoses were routed in my engine, made it look like the hose went to that disk thing. No biggie. Car runs better, I'm happy.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
mdtoren
Aug 16, 2015 05:45 PM
