Spline Pinion?
Old Feb 22, 2006 | 12:38 AM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
Spline Pinion?
Hey i was just trying to figure out how to find out what my spline pinion number was and how to find out?
Old Feb 22, 2006 | 06:20 AM
ede's Avatar
ede
count the splines, why would you want to know? they never changed the spline count on the pinion. are you getting it mixed up with the 10 bolt axle spline count?
Old Feb 22, 2006 | 10:15 PM
Mr.Wolf's Avatar
Car: 87 Z28
ok here's why, i am planning on converting m y limited slip to posi and my drive shaft spline count is 28 and i was also wanting to change the rear gears from 2.73-3.73 and need to know what my Spline Pinion count is 27, 30, Etc.? any one know
Old Feb 22, 2006 | 10:18 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
i always thought that the axle splines were the only thing that changed
Old Feb 22, 2006 | 10:31 PM
Mr.Wolf's Avatar
Car: 87 Z28
well cause thats the thing when i was looking at the new gears section in jegs or summit for gears u look for spline pinion. and when looking for a posi you look for spline
Old Feb 22, 2006 | 10:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All 7.5/7.625 pinions are 27 spline. There are no other options for this 10 bolt.
Axle splines are something different. 1989 and older 7.5" 10 bolts are 26 spline. 1990 and up are 28 spline axles.
Old Feb 23, 2006 | 11:50 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
you mean 26 spline . I just did mine
Old Feb 24, 2006 | 06:10 AM
All GM 7.5" / 7.625" pinions have 27 splines, like Stephen said; and are 1.438" diameter.
Yes I've done a certain number of them myself as well, over the years; in these cars, as well as others that use the same rear.
90-up axles and the carrier side gears usually have 28 splines.
88-back axles and side gears always have 26 splines.
89 rears could have either; a large majority got the 26s, but a few got the later model stuff. Probably something like 80-85% vs 15-20%.
There is no error in Stephen's post.
Old Feb 24, 2006 | 06:38 AM
ede's Avatar
ede
i just reread your reply and this is going to be alot easier than you thought, and cheaper. the only big differance between limited slip and posi is the way the letters are arranged. you already have posi if you have limited slip, or you already have limited slip if you have posi.
Old Feb 24, 2006 | 04:02 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
The spline count never changed even to date? So all 3rd/4th gen gears are swappable huh...for some reason I had the wacky idea that some pinions had 30 splines.
Old Feb 24, 2006 | 05:13 PM
Some do.
Just not any of the ones in GM 7.5" rears.
Old Feb 24, 2006 | 08:23 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Oh , crap I thought he ment axles Sorry about that .
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
Numbah-1
Sep 20, 2015 09:31 AM
dimented24x7
Sep 17, 2015 06:58 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
