T-56 with no computer
Old Feb 23, 2006 | 05:00 PM
crazyjim's Avatar
Car: 1989 Firebird
Engine: a monster
So I'm building a ragged edged street car. Full aluminum dash, carbbed setup... NO computer and as LITTLE wiring as possible. Aftermarket column, doing away with vats, EVERYTHING is going except the bare essentials. My question is, can I run a T-56 with out using any of the electronics. I know my speedo won't work, but since I'm using autometer gauges I figured I'd do this;
I'll just run a single large tach in the middle of the drivers side dash and the rest of the neccesary gauges (fuel, oil press, volts, etc) As far as a speedo, for the price of an autometer speedo I could just throw some extra cash down for a G-tech or something of that nature and get true GPS speed. Any body see a problem with this?
Old Feb 23, 2006 | 05:39 PM
The T-56 doesn't need a computer for anything.
As far as the speedo, that's up to you. GPS would work, as far as that goes. Not sure where a G-tech fits in though. Alternatively, you could use the T-56's pulse generator, and a Dakota Digital box, and an electronic speedo such as an Autometer. Might cost less than GPS, and would certainly be a faster responding setup.
Old Feb 23, 2006 | 05:46 PM
crazyjim's Avatar
Car: 1989 Firebird
Engine: a monster
See that's what I was referring to. I was reading a thread about some people having problems getting the dakota digital boxes working properly. Getting them calibrated too. After looking, I just found out the G-tech doesn't have a speedometer, which they should. IMO
Old Feb 23, 2006 | 06:15 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
All you need is a good memory and a tach. Use the GPS as a reference to get the speed and note your RPMs in that gear and you are good to go.
An Autometer speedo is very easy to setup with the T56, just mark a 2 mile stretch, put the speedo in calibration mode, drive the 2 miles and stop, press the calibration button and you are done. T56 puts out 4000 pulse/mile.
Old Feb 23, 2006 | 06:22 PM
I don't think a T-56 puts out 4000 pulses per mile. It would be more like 40,000. IIRC the reluctor has 17 teeth; so that's 17 pulses per drive shaft revolution. Still, if that's within the range that the speedo can adjust itself too, it would work without the box, to turn it into 2000 or 400 pulses per mile.
The reason a G-tech can't possibly have a speedo, is because over the long term, it has no clue how fast it's going. It's an accelerometer. It measures the force placed on it that tends to accelerate it. So for a short time & distance, it's pretty darn accurate; but over a long time, even just a few minutes, any electronic drift in it, magnifies itself. Probably be OK in the city, if you re-zeroed it every time you stopped; wouldn't be worth a crap on the highway.
Old Feb 24, 2006 | 02:13 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You could run a GPS speedo like they use in powerboats. A Autometer progammable speedo should work.
Old Feb 24, 2006 | 05:07 PM
Zepher's Avatar
I could be wrong, but when we were setting the Autometer speedo it went to 7980 in teh 2 miles on the ODO when we were setting it. it's been a few years since we did it and that might have been with the 4L60E.
Old Feb 24, 2006 | 05:21 PM
Well I wasn't there, so I'll take your word for that.
However: with 27" tires, your car goes about 84.82" per tire rotation. Divide 1 mile, or 5280' by that, you come out with about 747 tire revolutions per mile. Multiply that by a typical street rear gear ratio, say 3.73, and you find that the drive shaft rotates about 2784 times per mile. Multiply that by what you see in the pic, call it 17 teeth for the sake of argument, you come out with about 47,330 pulses per mile.
I have no clue what the 4L60E speedo apparatus is. But, there you have the numbers for the T-56 one.
Old Feb 25, 2006 | 01:52 AM
dab2pds's Avatar
Car: 05 corolla xrs, 05 hayabusa, 91 rs
Engine: 383
Transmission: t56
electrical speedo
i was looking at these on jegs. this one runs about 200$. description below:
Speedometer, 200-MPH, In-Dash Mount
105-4490
This programmable speedos feature ''push-button calibration'' that can be easily set while driving. This makes changing gear ratio or tire size easier than ever. The LCD odometer is highly visible and retains the actual mileage after recalibration or in the event 12-volt power is removed, also includes a resettable trip odometer. Will work with late-model transmissions that have an electronic (500 to 400,000 pulse/mile sender) output. Requires sender 105-5291 or 105-5292, if using an early model (cable driven speedo style) transmission.
tonys91rs
Oct 10, 2015 03:31 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
