Wierd sound, like Input Shaft Play or somethin
Old Feb 23, 2006 | 06:23 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
I temporarily have a T5 in my Camaro, and if I tap the gas or push in the clutch and let it out real quick, or anything that makes the car buck/jolt, there is this clunking sound comming from the front of the tranny area. It only happens when between 1000-1500rpm. It sounds like grabbing the input shaft and pushing it down,up,down,up,etc. It dosent happen real fast, and no matter what speed, it always clunks at the same rate. I checked the tranny mount, crossmember, tranny to bellhousing bolts, bellhousing to engine bolts, and the flywheel, all tight.
Is it just cuz the engine dosent make much power under 1500, and dosent like have to work at that low of rpm? So its bucking like when getting a bad start with a manual tranny, but while moving
dbrochard
Oct 3, 2015 12:43 PM
amcnellis
Sep 16, 2015 04:16 PM
dbrochard
Sep 7, 2015 09:41 AM
andy74
Sep 3, 2015 08:41 AM
tonys91rs
Sep 2, 2015 07:07 PM
