Reverse drivetrain direction
Old Feb 24, 2006 | 12:52 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
How would you change the direction of a drivetrain. For instance, if you wanted to put an lS1 in a corvair, it's facing the wrong direction (assuming you use a vette transaxle also). How would you change it. It's computer controlled so the only thing I could think would be moving coil packs around. Any info appreciated. Thx.
Ben
Old Feb 24, 2006 | 01:09 PM
ede's Avatar
ede
idler gears, reverse grind ring and pinion, reverse the rotation of the engine
Old Feb 24, 2006 | 03:02 PM
TABANDIT's Avatar
Car: 1987 Transam
Engine: 1991 350 Bored .030 over
Transmission: TH350 w/stage 2 shift kit
Another way to do it is to either turn the whole transaxle upside 180* (left tire becomes right tire and vice-a-versa, I know you can do this with a rear-end, not sure if a trans-axle would still bolt up to motor or not) or switch the sides that all the gears in the carrier are on (eg. ring gear is on the left, switch it to the right). I saw the last method done on a Volkswagen transaxle for a dunebuggy, and it took all the abuse that we could give to it.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gixxer92
May 18, 2017 11:20 AM
efiguy
Sep 27, 2015 01:30 PM
Lmancha96
Sep 25, 2015 08:11 PM
