I cant tell if im going into overdrive or not...
Old Feb 26, 2006 | 07:03 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
LOSING GEARS!
Ok, so i put a new tranny in my car (well used, but a gm rebuild with 15 on it and a 2400 stall that was used with it). anyways i was driving it around and it seemed pretty normal the first couple time i took it out. anyways, today it was acting weird. it had 3 shifts, but they were all over by 30 mph. and all the shifts were only dropping the rpms by like 50. so it would shift at 1500 and drop to 1400-1450ish. and by 30 i was in the 4th gear avaiable and no more shifts all the way up to 60 (im guessing that was od then, but the rpms were going way up and it seemed like it should have shifted again). anyways, i readjusted the tv cable, same thing, 3 shifts, all small rpm drops, and all occured by 30 mph. what is wrong here? i need any help i can get, thanks a lot.
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
