10 bolt eaton posi strange 410 gears 26spline less than 2000miles in my 89 383 mini ram 350 turbo 4000 stall 8inch coan converter about 425 hp 424trq need to kown fast dont have alot of cash this rear only 600 is this good for the money but will it hold up
i would say if it was yours give it a try' but since you are going to buy it save for something better like a 12 bolt or 9 inch . i have the same set up except i have a carb'd engine and the car had a big block before i got it and it held up with slicks except the axles which kept breaking
I changed my posi over to 28 spline with moser forged axles. I also have the support cover, welded axle tubes, and c-clip elminators. It has done the trick so far.
Josh I believe you will break axles with that kinda setup with the high rpm stall and such. I think it would be a good idea to invest in a quality rear end from moser, strange, or the like. Just my
i'd never pay $600 for a 10 bolt rear end. save up your pennies and get a 9" or 12 bolt. You can even buy a 9 bolt rear end for around $200-300 in good shape and it should hold up longer than a 10 bolt would.
