t-5 swapping ?
Old Mar 12, 2006 | 11:33 AM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
t-5 swaping ?
I swaped my auto 700 r4 to a t5 but engine rve funny is there a cure there is no speedo hooked ithink that is it any one do the swap with a 350 tpi out of a 88 chevy camaro the speedo is man
Old Mar 12, 2006 | 12:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your post was really hard to understand, but I think you're asking about what to do with the speedometer since you swapped from an automatic to a T5? You need the speedometer adapter from an 83-89 T5 transmission. It'll use your existing cable drive. Also make sure the speedo gears inside the trans are correct for your rear end gears, or your speedometer will be off.
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
