Transmission trouble... or not?
Old Mar 20, 2006 | 04:13 PM
gijeff350's Avatar
I installed a 700r4 that I rebuilt in my garage. Its got a new torque converter with a 2000 stall, manual valve body, new pumps, kevlar bands and clutches, cool servos, and the lock ups gone. The engine is also freshly built, sounds like it runs great, and passes the compression test. The problem is that the car moves very, very slow under any kind of load. Could there be something wrong with the transmission and what do you think it could be? Or is the source of my problem in the engine?
Old Mar 20, 2006 | 06:36 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
hows your tv cable look? did you reset it or use a different induction setup and throw the geometry off?
did you put fluid in the tranny?
Old Mar 20, 2006 | 08:41 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
what method did you use to get rid of the lock-up? if you left out the lock-up solenoid, then you have a huge fluid pressure loss. if you didn't modify the tranny properly, it will mess things up. you can't just get a torque convertor with no lock-up clutch to get rid of the lock-up feature.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
