whats wrong with my 700r4?
Old Mar 22, 2006 | 09:10 AM
icemanohio69's Avatar
Car: 2000 xtreme
Engine: 4.3L
this is a rebuilt 700r4 from tpi transmission about 3 years old with about 25,000 miles on it Ive not been hard on this trans only been to the drag strip once this is what happened i was driving along the road in front of my house witch has some snow on the road just a little in spots my tires were spinning not fast or anything then i hit a wet spot where the snow ended and my car quit pulling like it went in neutral i heard no noise whatsoever now i have no gears just park what happened?
Old Mar 22, 2006 | 12:51 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
You will not know till you open it up. I broke a rear planetary, reaction shaft and an output shaft when the same thing happened to me.
Old Mar 22, 2006 | 03:37 PM
Car: 2000 xtreme
Engine: 4.3L
if my filter fell off could this cause this?
Old Mar 22, 2006 | 07:07 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I lost the 700r4 in my 82 Blazer (same symptoms, different circumstances). Just going down the road about 20 mph and heard/felt a noise like I'd run over something in the road. Didn't realize there was anything wrong until I started trying to climb the next hill. I'd coasted several hundred yards between the noise and putting my foot back on the gas pedal. The engine would rev up but I had no power transfer to the rear is any gear selection. The repair shop gave me a box of fragmented pieces back. The planetary gear set only had one complete gear left in the main ring and the whole center of that was busted loose from the outside ring. It just self destructed with almost no load on it. I was on level ground and was coasting along getting ready to brake before going through a 90 degree sharply downhill curve. It happens.
Old Mar 23, 2006 | 06:49 PM
Car: 2000 xtreme
Engine: 4.3L
Would this leave metal in the pan? I took the pan off and it is clean the fluid it super clean. I didn't mention above that i serviced this transmission about 2 weeks ago. New filter gasket and about 5 qts b&m trick shift fluid. The filter didn't fall off it was still up in there. When i checked the fluid it was about 2 qts over full and this changed very little with the engine running and warm. THANKS for all the replies.
Old Mar 24, 2006 | 07:03 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Is this in all ranges?
Have you tried OD, D, second, and first? And reverse?
In OD and D it uses the clutches to engage, and in second and first it uses the band. However that wouldn't explain no reverse.
Low fluid pressure can cause it, (like if your front pump disintegrated), you could check by pulling the radiator tranny cooler line and just starting the car. You'll instantly know if you have pressure LOL. Theres a tap you can put a pressure gauge on if you don't want to deal with the tranny fluid everywhere.
Could the flex plate to torque convertor bolts have sheared or fallen out? Or maybe your tranny slipped back and somehow pulled the converter off the tranny?
I'm just brainstorming here, stuff externally you could check. Best bet is to just open it up and see...
Old Mar 24, 2006 | 07:25 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
which filter and how the hell would it fall off?
Old Mar 25, 2006 | 11:47 AM
Car: 2000 xtreme
Engine: 4.3L
i have no 1st no 2nd no drive no overdrive no reverse just park i started to pull tranny out torque convertor bolts were fine good and tight i just have a few more bolts to pull and the lines first I'm going to check out the pump what check i check visually at the pump? to tell if it bad thanks for your help
I'm talking about the transmission filter the only thing that holds it in is like a rubber ring thing inside the transmission pan i don't know what the name for it is i have seen them fall out before but thats not what happened here thanks for your reply
Last edited by icemanohio69; Mar 25, 2006 at 11:51 AM. Reason: Automerged Doublepost
Old Mar 26, 2006 | 09:01 PM
Car: 2000 xtreme
Engine: 4.3L
pics
check out these
http://i52.photobucket.com/albums/g2...26-06_2033.jpg
http://i52.photobucket.com/albums/g2...26-06_2034.jpg
what should i do?
new pump
what about the torque converter think it will be OK?
looks like all the parts stayed I'm the pump
Old Mar 26, 2006 | 09:12 PM
brewersprts's Avatar
My buddies have broke input and output shafts on theres just driving down the road. But is was prolly from them playing with it and getting on it before that time and it just finally gave out. Kinda did the same kinda thing.
Old Mar 26, 2006 | 10:37 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I would replace the entire pump assembly and the torque converter. The convertor might not be damaged, but if you got some crap in the vanes, you will find out the hard way. I wouldn't bother just replacing the vanes and pump, for the extra money you can have a new unit that won't have any scratches or gouges. You can get pretty good deals at www.technicalvideos.com. I have ordered several parts through them and they have always had the time to discuss my options.
Old Mar 27, 2006 | 02:00 AM
Pro Built Automatics's Avatar
You say park works (vehicle cannot be moved in either direction, and the driveshaft does not spin when you put it in gear?), then it is most likely that the input shaft, or the input drum broke.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
